2n won`t start
homeboy
09-09-2000 16:31:47
I have owned a 2n for about 6-7 months. I have had the gen rebuilt and a new coil installed . It has run great until last week. It has a 8volt battery that has put out alot of corroison. I cleaned it up and reinstalleed it and would not start. I have used a 12volt to bAtt. terminal it turned the started like crazy but no start up. I put a new 8volt still nothing . I tried to start by using screw driver to short-out the selonid still dead in the water. Switch has power across it and power through the resisiter.Any idea would be greatly appreciated. homeboy
Cort in Montana
09-10-2000 09:06:43
 Re: 2n won`t start in reply to homeboy, 09-09-2000 16:31:47
Is the starter motor turning the engine over? Is your key in the on position? Is there gasoline in the fuel tank, and is that gasoline actually making it down to the carburetor?
homeboy
09-10-2000 12:46:31
 Re: Re: 2n won`t start in reply to Cort in Montana, 09-10-2000 09:06:43
Cort; Thanks for the reply. Yes the switch is on and passing current.The fuel part is great,no stoppages, the started will turn over with a 12 volt connected directly to the starter lug, but the engine will not fire. I does turn over fast with 12 volt to it.It is basically a 6 volt system but the previous owner up it to 8 volt and has done great. I have put a new 8 volt back in it the battery appreared shot. When I put the new battery in it started right up and ran for a while . The next day it is dead again.I have tried to start it with a screw driver across the selenoid but won`t even spark. The battery is brand new and has about 8.3 volt across the poles with the old dc meterI turn the switch on and press the started button (out of gear of course) and nothing happens. This old machine has always been an easy starter until now. Any help would be much appreciated and thanks for your interest. homeboy
