Is this common???
CHRIS-8N (aka C
09-08-2000 20:20:43
helping my neighbor get his 8n going (has sit inside for two years) cleaned points, charge batt, rebuilt carb, rings seem to be stuck feeding it marvel oil, now here's the problem the clutch will not disenge, tried adj but just will not disengage. any ideas? it is a 52 model. thanks.
raytasch
09-09-2000 08:08:22
 Re: is this common??? in reply to CHRIS-8N (aka CHRIS-MF35), 09-08-2000 20:20:43
1-Head it out to where you have room to run it around. 2-Jack a rear wheel up, start the engine. 3-Pull tractor in to gear. 4-Depress clutch.
5-Have someone push tractor off blocks.
6-Repeat 1-5 if the above fails first time.
Figure out and understand what you are going to do before you start. If you are not comfortable with the proceedure DON'T DO IT! It will work. ray
CHRIS-MF35
09-09-2000 08:01:30
i can't believe it but it was 5 full turns out of adj. people with no mech. abbilty should not own old iron. it just put more free work on us that do. (he does at least offer to pay though) thanks
John
09-08-2000 21:24:07
It sounds like the clutch is stuck. This can happen if a tractor is not used for a long period. One way to free it is to start the tractor in gear by towing and then push in the clutch and apply the brakes at the same time to put a load on it. Any way that you can load the tracor while having the clutch in may work. Be carefull and good luck.
paul
09-08-2000 23:13:17
 Re: Re: is this common??? in reply to John, 09-08-2000 21:24:07
Um, if you tow the tractor, it starts, but the clutch won't let go, I sure hope you are thinking about how to stop that tractor before it runs over the tow-er!
Rolling down a hill might at least invlove one less person & vehicle in the crash. :)
--->Paul
Salmoneye
09-09-2000 05:09:50
 Re: Re: Re: is this common??? in reply to paul, 09-08-2000 23:13:17
yeah, but....
How do you get it to the top of the hill?
And then how do you get it rolling in gear?
Tow truck with a pushing bumper maybe?
Then what do you push on in the rear of the tractor?
Arghhhh!... Too early for brain teasers...
Just block the clutch down, put it in fourth gear and one guy get on each rear wheel and rock the livin' begeezes out of her front to back. It has worked in the past.
paul
09-10-2000 20:38:04
 Re: Re: Re: Re: is this common??? in reply to Salmoneye, 09-09-2000 05:09:50
Well, just pull it to the top of the hill (in neutral, key off) with your other tractor or a pickup.
But then, I have 2 pickups & 5 tractors. And I do not have a flat spot on any of my 200 acres. Maybe some of you don't have a second tractor? And I hear rumors there are places that don't even have a hill, altho I can't imagine such a thing!
--->Paul
Dale O'9N
09-09-2000 11:14:17
Your idea sounds much safer than the two person multi-vehicle collision described earlier. As soon as the clutch pops, it will free up all at once. A few times rocking the rear tires should do the trick. IF, however it is still stuck, the only way I would pull it , is to leave the key or ignition wire off. These things will just go when you start them in gear. Don't ask how I know. Claus already got me for that one. Be safe. Dale in VA.
