Another coil or electrical question just a little different than Sal's
Grant
09-05-2000 19:42:02
I had my 1950 8n 6V tractor die while mowing. I replaced the coil and the wiring harness(it really needed it) plus plugs, points condensor and distributor cap. The plug wires were new last year. Now it won't start. It turns over fine, the lights work and I get spark to the coil but nothing out of it. I bought a second coil but nothing from it either. I tried reversing the polarites on the coil but nothing there. Any suggestions before I spend all my beer money on coils?
ZANE
09-05-2000 20:30:49
 Re: Another coil or electrical question just a little different than Sal's in reply to Grant, 09-05-2000 19:42:02
If it is a side mounted distributor you should remove the cap. Open the points by turning the engine over. Take the high tension wire out of the center of the cap and hold it about a quarter inch from the block and with the ignition switch on take an insulated screw driver and make contack between the two parts of the points just off the points themselves. If you are getting fire to the points you should get lots of fire from the high tension wire at the block. If no fire then you should look and be sure that the insulator where the points wire goes through the distributor side is not shorted out. These insulatore like to do that!
If it fires with the screw driver between the two parts of the points then turn the engine till the points are closed and then open and close them with the screw driver to see if they are making contact. If the points have any oil on them they will not work. This means even the oil from your finger tips.
norm-wy
09-05-2000 20:21:34
Grant
You said < I get spark to the coil but nothing out of it>. Not sure what you mean. You shouldnt get any spark at the input or primary of the coil. You should only get spark from the secondary or high voltage lead of the coil or the plugs. Can you clarify?
Grant
09-06-2000 06:14:15
 Re: Re: Another coil or electrical question just a little different than Sal's in reply to norm-wy, 09-05-2000 20:21:34
I don't get any spark from the plugs or the high voltage lead of the coil. Looks like I need to check the points etc. and I'll let you know what I find there. Thanks.
Grant
Kev8n
09-05-2000 20:00:18
Since you verified that you have voltage to the coil, I would start at the points and work out. Check to make sure your gap is correct.
Once verified, then test them with an ohm meter that the points are opening and closing completely. On a front mount, you can follow the instructions listed on:
Link
Since I've never worked on a side mount, I don't know how that changes it, but I would think the method described there would be somewhat applicable. Maybe someone else has some more info.
Once that is verified, work out from there. Don8NAZ had a nice post a couple days ago on checking sparks... see it.
Link
Hope that helps some... good luck!
Kevin
