6V to 12V Distributor coil replacement ?
Chad
09-03-2000 09:48:02
I have an old 8N that has been half way converted to 12V. It had a 6V distributor coil using a resistor to drop the voltage. My resistor went out. I changed the distributor coil to a 12V instead of getting a new resister. After 30 minutes of running time my tractor shut down, I pulled the coil back off and it had burnt the coiled conductor off the bottom of the coil. Has anyone had a similar experience or know what I did wrong?
Claus is correct........Dell (WA)
09-03-2000 12:49:43
 Re: 6V to 12V Distributor coil replacement ? in reply to Chad, 09-03-2000 09:48:02
Chad..... .in the typical frontmount 12 volt conversion, in the days of before the 12 volt front mount coil, 2 resistors were needed to make the conversion work. A 12 volt to 6 volt converting resistor and the standard "ballast resistor" mounted to the back of the tractor dash panel.
Now, howsomever, with the manufacturing of a frontmount 12 volt coil, some current control is still needed to prevent the coil or points from burning out. Which is what the OEM ballast resistor was doing to the OEM 6 volt coil.
There should have been an instruction sheet with your new 12 volt frontmount coil, telling your what size resistance is needed to prevent your coil from burning out. You may have been lucky and just have burned out your coil contactor. But you still need that resistor, find your installation sheet and do it right..... ..Dell
Claus
09-03-2000 11:05:09
You still need a ballast resistor when using the 12 volt front mounted coil. The 12 to 6 volt dropping resistor is the one that you would remove when changing to a 12 volt coil. Happy Motoring
Claus
Chris Erlon
09-03-2000 11:55:11
 Re: Re: 6V to 12V Distributor coil replacement ? in reply to Claus, 09-03-2000 11:05:09
Where does the ballast resistor go? When I bought a new coil for my Jubilee, I asked for the resistor, and the parts guy insisted that the resistor was built into the coil. Is that right?
Than
no.....Dell (WA)
09-03-2000 12:30:52
 Re: Re: Re: 6V to 12V Distributor coil replacement ? in reply to Chris Erlon, 09-03-2000 11:55:11
Chris..... ...sidemount distributor Jubelee's are different than frontmount early 8N's.
If you got the general purpose, one size fits all, sidemount coil from Ford, then indeed the coil does need a voltage converting resistor to work with 12 volts but does not need a resistor to work with 6 volts.
And NO, there is not a "built-in" resistor in any ignition coil. Yes, there is resistance in the form of coil wire resistance but to purposely add additional internal resistance is blattent nonsense.
All electrical conductors (wires) must have, by laws of physics, resistance to the flow of electrons. Copper has less resistance that iron for example and plastic or glass have a whole lot of resistance to electrons therefore they are called "insolators".
Chris..... .There is a lot of electrial mis-information out there. You might want to check the "archives" at the top of the N-Board for the straight skinney..... Dell
Claus
09-03-2000 12:23:22
Yes, same on the 6 volt side mounted 8N...The parts guy is correct....
Happy Motoring
Claus
Bob (KY)
09-03-2000 10:15:10
Yep Chad sorry too say you GOT to have that resistor. Check in the archives for the specifics on measuring voltage and the "why's and what for's". Or maybe Claus and the other experts will response pretty quick.
Good Luck
Bob (KY)
STUMP PULLER
09-03-2000 18:25:16
 Re: Re: 6V to 12V Distributor coil replacement ? in reply to Bob (KY), 09-03-2000 10:15:10
THERE ARE A LOT OF DIFFERENT COILS OUT THERE, AND THERE ARE AVAILABLE COILS THAT ARE TRULY 12V THAT DO NOT REQUIRE A BALLAST RESISTOR. MY COIL IS LIKE THAT AND IT MEASURES ABOUT 3.5 OHMS. THIS IS ON A SIDE MOUNT DISTRIBUTOR SYSTEM.
