Order Ford 8N Parts Online
8N Ignition Wiring
Craig (WA)
09-01-2000 20:33:47
My newly purchased 8N was rewired to a 12 volt system and whoever did it modified the ignition switch system. The top (origingal ??) switch has a single wire in with nothing out. The push button has be bypassed and the new switch acts like a key switch. This requires the solenoid be jumped in order to start. Where can I get the correct wiring requirements? Any other suggestions?
bg
09-01-2000 21:00:59
 Re: 8N Ignition Wiring in reply to Craig (WA), 09-01-2000 20:33:47
Go to Neil Reitmeyer's nseries.com for wiring schematics. The switch probably wore out or burned out. Buy a new one. It has a safety lockout so you can only start in neutral. The single wire is all thatis needed as it is supposed to complete the ground circuit when it is pressed. The 12 volt conversion should not necessitate changing components of the starting system, only the ignition and charging systems.
