I finished tearing down my 8N yesterday and can't quite figure out what the main problem was, so I thought I'd submit the evidence to the collective wisdom of this board to see if any of you have an opinion.History: I changed out the muffler to quiet things down a bit. While clamping the exhaust pipe to the manifold, I noticed a crack in the manifold between the exhaust ports on the #3 and #4 cylinders. I installed the muffler and ran about 4 hours to finish up the job. Symptoms: A significant loss of power and large increase in blow by (all suddenly after about 4 hours). After tear down: The manifold crack was MUCH larger than before. The exhaust valves on both #3 and #4 cylinders were tan colored with blued stems, #1 and #2 were blackened with no bluing. The top ring on both #3 and #4 cylinders broke while removing the pistons (surfaces on the breaks were clean and fresh), #1 and #2 were just fine. All cylinders are smooth, no scoring or ridges. All pistons were uniformly covered with black carbon. Valve seats all look OK, no pitting or discoloration. I've got a new muffler for my other 8N, but now I'm goosey to put it on. I'm lucky to have 2 tractors and if I have another rebuild on my hands, the Mrs. will surely downsize my fleet for me! Any ideas what I did to the poor thing? Larry
