Order Ford 9N Parts Online
9N in my sights to purchase; questions up front
Ken Tolbert
08-27-2000 15:54:22
Looking at a (S/N 9N341) Initial questions:
a) 3PH won't raise or lower; owner stated he manually lifted the 3PH upward to determine amount of play, heard a click and it hasn't worked since (saw a ref to '51 8N 3PH won't raise or lower; same solution?, i.e. control arm NOT in contact with the pocket of the rocker on the pump)
b) Owner installed 12 volt alternator, but has jury rigged, to get the battery to charge, a wire with alligator clip, that he removes from some
connection, after he gets the tractor started.
c) Owner claims it will use a quart of oil about every 30-40 hours of use and engine smokes a bit after full day of mowing.
d) Will charge battery and start next week to check on other essentials.
Any input is appreciated. thanks in advance
ken
9n'er
08-28-2000 03:31:11
 Re: 9N in my sights to purchase; questions up front in reply to Ken Tolbert, 08-27-2000 15:54:22
Hi Ken: Serial Number 341 at 2k or 1.5k is a good buy, as noted below, that is a low serial number and should contain an aluminum dash, perhaps tranny cover, inspection plates, and front grille (if any of these parts made it through the last 61 years). 5 months ago I wouldn't have paid all that much attention to serial numbers and 9N's for that matter. But since I did a partial restoration (about 80%), and learning, studying and talking with people I would just about die for that tractor (well almost). For a guy like me, I would purchase it, try to talk him down of course and be happy with it no matter what the condition of the fixable mechanics are. Just my 2 cents worth, so if ya get tired of it, look me up I'll find the money somehow. I wish I had that kind of luck. One last rambling thought: 9N's are perfectly fine little tractors. I like em' because they are early Fords, and I don't seee many complete and fully restored 9N's like I do 8N's or NAA's. Initially I wanted a NAA or 8N, but since I aquired this 9N worked it over, and now working it a bit, I am impressed with it to no end; the low gear reverse it great, and I don't really need a 4th speed. A Zane Thang will help one limitation and someday that will be installed. I'm happy with it even with the inconvenience of the brake pedals on each side and front mount distributor. I would almost trade up my 9N for your 341...but I may have to think about it some too. E-mail me if ya want I would be interested and others' on this Board would be curious to know what aluminum parts remain on it. Good find, good for you. 9N'er
Bob
08-27-2000 19:36:37
If that is the correct serial number, and the tractor hasn't been beat to a pulp, you could always re-sell it to a collector who is looking for a low serial number N. Demand for low #'s is rising, I wish I had seen it first!! Good luck...
Dale O'9N
08-27-2000 16:17:08
If the price is right, get it. Ser # 9N 341 is very collectible. The oil burn rate is actually not bad. I've seen some that are running great that go through a qt. every 10 to 12 hrs. My 42 9N is running about like the one you are looking at. Need more info on hyd trouble. But you should be able to get what you need in some earlier posts. You didn't mention the price. Post back with what you plan to offer. I'm quite sure all of us would like to know. Good luck. Dale in VA.
ken tolbert
08-27-2000 16:53:02
 Re: Re: 9N in my sights to purchase; questions up front in reply to Dale O'9N, 08-27-2000 16:17:08
Owner is asking 2000, I am trying for 1500.
do all 9Ns have a gear shift (for road driving) on the left side forward and beneath the starter?
All junctions (metal to metal) seem to be very tight. I will know more early next week. I will also try to operate the 3PH and determine what it acts like and what I hear. Owner used the tractor until he disable the 3PH. What other areas can I observe to verify the integrity of the machine? Thanks for your quick response. ken
2fords
08-27-2000 17:19:21
 Re: Re: Re: 9N in my sights to purchase; questions up front in reply to ken tolbert, 08-27-2000 16:53:02
Not all 9Ns don't have the extra gear shifter and extra gear or gears. That is a plus if it is an overdrive and greater plus if it is an under and over-drive (it will give you 9 speeds forward).
Can you go drive another 9N, 2N or 8N to compare with this one? Don't hesitate to call somebody you barely know who has one.
EDDIE
08-27-2000 18:06:52
 Re: Re: Re: Re: 9N in my sights to purchase; questions up front in reply to 2fords, 08-27-2000 17:19:21
SOUNDS LIKE PISTON PUSH ROD FELL OUT OF PLACE ON THE LIFT PROBLEM, NO BIG DEAL TO FIX IF THATS ALL IT WAS, MINE RUNS LIKE A TOP AND SMOKE A LITTLE ALL THE TIME AND USES ABT THE AMOUNT OF OIL YOU SAID THAT ONE DID, I JUST GOT DONE RUNNING IT APPROX 6 HOURS STRAIT BUSHHOGGING,RAN GREAT AND NEVER COMPLAINED, THE SHIFT LEVER ON DRIVER SIDE, IF IT IS JUST A SMALL DIAMETER ROD BENT TO COME UP TOWARDS THE DRIVER YOU HAVE EITHER A STEP UP OR STEP DOWN SHERMAN TRANS, IF IT IS A FAIRLY HEFTY LOOKING SHIFT LEVER IT SHOULD BE A SHERMAN COMBINATION , 12FWD, 3 REV SPEEDS, MINE HAS THE STEP DOWN, MOST EXCELLENT FOR PULLING HEAVY LOADS. PLEASE FEEL FREE TO ASK ALL THE QUESTIONS YOU HAVE SOMEONE ON HERE WILL BE GLAD TO SHARE THEIR KNOWLEDGE, I HAVE ASKED A BUNCH AND LEARNED A LOT ON HERE
