Order Ford 8N Parts Online
8n Distributor Moisture problem
Dan Manrique
08-27-2000 13:07:41
My Father-in-law is constanly having a problem starting his 8n whenever it has rained or is damp.He keeps it under a shed and places a tarp over the engine. The dist was replaced last year and the points and cond changed. It takes him 30 mins to an hour running a hair dryer on the dist. before it will crank. if the weather is dry it starts right up.Someone told him this is common with 8N's Any suggestions? Thanks!
ZANE
08-27-2000 14:41:40
 Re: 8n Distributor Moisture problem in reply to Dan Manrique, 08-27-2000 13:07:41
I have a 58 Ford F600 truck with the 292 V8 engine. The distributor is at the back of the engine nearly up under the fire wall and almost impossible to get to.
About 15 years ago I was using it to haul logs to the plywood mill off my sisters place and every time it got humid for any reason it would not start. One morning as I was jumping it off and wearing out the starter trying to get it to fire up the old black man who had helped me and my family for many years said to me,"Zane if you will spray some of that WD 40 all over the cap and wires and plugs I'll bet you it will start" Well I had never heard of anything so stupid sounding but I did have a big can of WD 40 I had just bought in the tool truck so just to satisfy Albert I sprayed everything I could get WD 40 on. I got back in the truck and it started right up and didn't skip or sputter one bit. Hey! It works!
I have done it many times since when the air if full of moisture and one of my many old pieces of iron won't go I just get out the trusty WD 40 and it works every time. (Don't spray it on the points)
Steve IA
08-27-2000 14:37:18
No guarantee, but I've had some luck spraying the OUTSIDE of the coil/dist. cap on my front mount lightly with WD-40. I rarely have any problem, only when I hose out the radiator, or right after a driving rain, so can't swear it will work all the time. Not sure how it works from the outside, but it might be worth a try. HTH
Steve 8N 169302
Claus is correct.......Dell (WA)
08-27-2000 14:32:40
Dan..... .This is not a common 8N problem. It is a common old engine problem.
I would also suggest that you replace the sparkplug wires. The insulation gets brittle and dried out and developes fine cracks that you can't see but moisture collects in and all the sparkies leak out the wire. If you don't believe me, go look at the wires when you run the tractor in the dark of the night and watch all the blue electrons sparkle all over the place. Use quality copper core sparkplug wires, not carbon core radio suppression type. cut and fit as required. Remember, firing order is 1,2,4,3. The numbers molded into the frontmount ignition cap are the cylinder numbers. ..... .Dell
Claus
08-27-2000 13:27:06
First, tell him to get rid of the tarp over the engine. The tarp will prevent evaporation of moisture on the engine. Next, check to see if the gaskets are in place on the coil and distributor cap and are making a tight seal.(I assume he has a front mount)
Happy Motring
Claus
