Order Ford 8N Parts Online
8N runs bushhog for 1hour then dies need help
John8N1949
08-25-2000 19:34:39
Just bought first 8N three weeks ago.
I can bushhog for about 1Hour in just grass and the 8N just dies. loses power will start for second then die. have to leave it come back next day starts lasts one hour then dies agian.
hope some can help
Paul
08-25-2000 20:34:10
 Re: 8N runs bushhog for 1hour then dies need help in reply to John8N1949, 08-25-2000 19:34:39
Sounds like to me you have a coil problem. I am not a expert by any means but when the coil gets hot it will short out and you will lose spark. After it quits, check and see if you still have spark. That is my 2 cents.
Good luck
Paul
Kev8n
08-27-2000 19:56:53
 Re: Re: 8N runs bushhog for 1hour then dies need help in reply to Paul, 08-25-2000 20:34:10
John:
Some things to check before purchasing the relatively expensive coil:
1. Pull the distributor off the front and check the point gap. It should be .015. Sometimes, on the front mount, they will slip together and work as described. Run for a while til it get's hot, then stop or just run ragged as all get out. I've personally experienced this one a lot until I bought a new breaker plate.
2. Once it's dead, bypass the ignition switch with a jumper wire. I believe Dell (WA) suggest this as one that he has seen. If by bypassing the switch the tractor starts, then your old switch is gunked up and you just need to replace it.
If the above doesn't work, then I would go for the new coil. Good luck and let us know what you find.
Kevin
'49 8N
John8N1949
08-25-2000 21:04:23
Should i buy 12volt or 6volt coil have 12volt
system but still have 6 volt coil, So if i am
buying new coil like to know w is best.
And where to buy coil for Front mount 8N1949? thanks Paul for reply.
Paul
08-26-2000 16:53:59
 Re: Re: Re: 8N runs bushhog for 1hour then dies need help in reply to John8N1949, 08-25-2000 21:04:23
I have a 12 volt convertion on my 9N. It had a 6 volt coil. I went with a 12 volt and it works great. If you change you will have to remove the resister to the coil for the 12 volt. You can get one from any of these places online or if you have a tractor supply around somewhere close they have them for less then $30.
Good luck
Paul
Jess (MO)
08-25-2000 22:28:25
I had the quickest response and the best price, incl. shipping from Mike's Tractors..Jess
