Order Ford 8N Parts Online
1951 8N
Walt Merritt
08-23-2000 13:59:32
I recently purchased a Ford 8N and after inspecting it found that the lower radiator hose was leaking. The system has been converted to 12volt and the alternator interfers with the normal lower radiator hose. A flex hose was in place to complete the system. Are there any other cures for the lower radiator hose?
Walt
Kevin-MN
08-24-2000 05:18:25
 Re: 1951 8N in reply to Walt Merritt, 08-23-2000 13:59:32
Double check normal. The side mount distributor uses a different hose than the front with a partial "loop" to go around the generator. The earlier hose is more like an elbow. Do you have the right one?
Kevin
bg
08-23-2000 14:40:24
You should be able to relocate the alternator by changing or modifying the bracket and belt to get enough clearance for the lower hose.
