Ballast Resistor wire diagram
Big Steve
08-19-2000 18:39:56
Still haven't figured out why the 8N I bought a few weeks ago won't start. It's a '48 with a front-mount distributor. Today I replaced the ballast resistor. Something looked funny to me about the wiring setup on the old one, but I don't know the correct wiring.
What stuck me is that a couple of the wires were attached to one side of the resistor block, but no wires attached to the other side, e.g. nothing going through the resistor.
I've looked in the archives and other sites for a diagram or description of what should be attached where on that block, and came up empty. Any help would be appreciated.
ZANE
08-19-2000 18:46:57
 Re: Ballast Resistor wire diagram in reply to Big Steve, 08-19-2000 18:39:56
What someone has done is to bypass the resistor thinking that might fix a weak ignition. BIG MISTAKE!
What it probably has done is burn up the ignition coil.
The resistor shoud have the wire coming from the ignition switch attached to one of the terminals and the wire coming from the ignition coil attached to the other terminal of the resistor. I would replace the resistor with a new one and also the ignition coil. I would replace the points and condenser too while I was at it so you will be sure and solve the ignition problem.
Check the ignition switch first to make sure it is making up. The 8N switch is notorious for going on the blink. One way to check it out is to take a straight pin and push it through both wires that go to the switch and then see if it will fire. If it will start then you will know it is the switch and you can replace it. When you have determined that the switch is delivering juice to the ignition the next thing to check is the resistor just above the ignition switch. If it is open it will not run. Don't try to bypass it if you determine it is bad but go and get a new one.
I repeat, don't bypass the resistor! You will toast everything in the ignition system if you do. There is a little card board looking insulator where the wire goes into the distributor. Sometimes this insulator will deterioiate and short out causing the ignition not to work. You can run a wire straight through the hole in the distributor to the points and then dab a little silicone glue in the hole with the wire to keep out dust and it will word just as good or better than the insulator and stud thing where it goes into the distributor.
If you have got sparks all the way to the points and still not any fire to the plugs you need to replace the points and condenser and then the coil if all else fails.
Big Steve
08-19-2000 20:33:57
 Re: Re: Ballast Resistor wire diagram in reply to ZANE, 08-19-2000 18:46:57
Thanks Zane. That's very helpful. I already put in new coil, points, condensor, resistor, & plugs. But the resistor was the last thing replaced so hopefully nothing's burned up. I'll wire it correctly in a couple days (got a wedding to go to tomorrow) and report on my findings.
I can also see that the key switch might be a problem -- it looked a bit funky but I ran outta time today.
