Order Ford 8N Parts Online
8N stablizer bars
Sully
08-16-2000 23:25:40
I recently purchased a 1949 Ford 8N and a 5' bush hog. I have looked through the different links trying to locate a pair of brackets and stablizer bars but can't find any, new or used. Does anyone know where I can find them?
Sully
TimK
08-17-2000 08:14:12
 Re: 8N stablizer bars in reply to Sully, 08-16-2000 23:25:40
Stevens 1-800-333-9143 offers a kit of lower bars, brackets, etc. $40.00
Geoff in MN
08-17-2000 06:27:43
I've been able to obtain the original lower type brackets and bars from Palmer Fossum but I have seen cheesy aftermarket kits at Fleet Farm. A friend of mine had the top link variety on his but these were more time consuming to remove and install, don't allow you to raise and lower your lift, and interfere with a draw bar lock if you wish to use one. I use the Zane Thang in conjunction with with the lower stabilizer arms and have found this to be the ideal setup for my 9N. Nothing is worse for the PTO shaft than having that big heavy mower swinging about. Incidentally, if you can find only one bracket and bar, then this is still better than using none at all. Where are you located? I can't make sense out of NL. Palmer's number is 507-645-8095 in MN. If you can't reach him, let me know since I wil be venturing down there to pick up my rebuild kit soon. Good Luck. Geoff
John (NL)
08-17-2000 06:54:16
 Re: Re: 8N stablizer bars in reply to Geoff in MN, 08-17-2000 06:27:43
NL means the Netherlands. I'm from Ohio originally, but live in Vessem in the south of Holland now, just 10 miles from the border with Belgium.
Brought my Great-grandfather's 8N with me. There is a New Holland dealer about 20 miles from me who can get most parts in a day or two. His father used to sell 8Ns after the war and he has a restored one in his shed. They call them "Dearborns" over here. I know of two others within a 50 mile radius and they are very popular at the oldtimer farm and harvest festivals.
Regards,
John
John (NL)
08-17-2000 01:14:38
There are two kinds of anti-sway bars.
Lower anti-sway bars are single piece bars and attach to brackets below the fenders on the back axle. They allow up and down movement of scraper blades and mowers, etc.
Upper anti-sway bars are two piece bars, adjustable in length, attach to the top link and will bend themselves or break your hydraulics if you try to use the lift. The are for use in pulling a trailer from a draw bar and such uses. The have notches which you can line up before tightening the adjustment bolts. When so adjusted, you get a hitch ball height on your draw bar at the recommended 14 inches above ground. The 8N originally had a small chain on the quadrant for use in locking the lever in the down position when the upper anti-sway bars were in use to protect from accidentally raising the lower arms and breaking something. These little chains have mostly disappeared.
You can get either kind at the local New Holland dealer or at a TSC or other farm supply store for between $20.00 and $30.00.
Good luck.
