Order Ford 8N Parts Online
8Ns in pulling contests
Snow Plow
08-11-2000 11:54:11
I recently joined the Maine Antique Tractor Club and noticed that they hold a lot of pulling contests. I also noticed that based on this years results the old Fords have been getting their buts kicked, or simply not competing. Only one 8N placed in its weight class this year. It was 8th out of 8 and only pulled a couple of feet so it got on the board.
What's the problem? Are the old fords outmatched pound for pound by some other tractor and just can't keep up? Same weight more HP?
Any tips if I should try hooking the old girl (51' 8N) up and pulling.
ps They did have a beautiful 8N with a scraper blade cleaning up and smoothing the track!
Dave in Mo
08-15-2000 04:38:54
 Re: 8Ns in pulling contests in reply to Snow Plow, 08-11-2000 11:54:11
The two pulls I've entered had about 150 entries and I never did see an "N" there. There are multiple reasons for this but the big one is that all the Fords are on the farm working (and look like it). I brought my Farmall 'A' to compete because without a three point hitch, it's kinda worthless for working and besides, it's painted real pretty. Also, most 8N's are worn out (from my experiences) which gives the illusion that they are underpowered. Most people who pull have more knowledge on how to do this too, such as running 7-10 psi in the tires and certain tread cuts etc. It usually gets out of hand right away because everyone wants to win so bad. It's really sad how people will modify their machines just to win. I quit going because of the inequities. The stock classes are anything but.
Bob (KY)
08-12-2000 07:37:06
Snow Plow, I searched the archives and couldn't find anything on the guy that had the 8N (could of been a 9N/2N) pulling tractor. Someone even posted a photo of it. You might try this post on the Tractor Pulling and/or Tractor Talk forums and someone may respond w/ that info.
Also you should get some other info as to tricks of the trade. Drawbar height adjustments, weights and distribution of weights, tire pressure,etc...
I dare not "pull" my 2N as I fear that when I win, a certain class of tractor people would be "GREEN" with envy when they see a REAL tractor pull. (HAR HAR HAR)
If you decide to "pull", understand the rules. There are always those that like to bend and use the rules to their favor. These antique pulls should really be more for fun than anything else.
Good Luck
mike
08-12-2000 06:24:50
The real reason is that all of the tractors need to be "original" as seen from the outside. Soooo, all the JD and Farmall people modify everything inside to get more HP. For example, my neighbor has 3 tractors each rated for Nebraska test of 38-42hp. Now they are 55, 70, and 100hp. I ran into a guy who went up against them with a stock farmall as it was a "stock" pull. He cried unfair, but that's the rules of the game.
I think thr fords could do it, just harder to modify in the stroke and boring to get a 100 hp to be competitive. The other problem as previously stated is weight. JD's tend to be longer and heavier. More weight, better pulling. Need to ad a lot oe weight to an N.
My $.02
Mike
Ed Gooding (VA)
08-12-2000 03:08:27
Bob McMulkin is selling his Funk 8N, with a 95hp six cyl. engine in it, on Ebay. Bet that sucker would pull a little better!
LOL>..... .....Ed
'52 8N475798
Steve
08-11-2000 21:49:04
I Have a 9N and have entered it in two pulls. The light class out here (Oregon) is 3000#. The first pull I weighed 2670# and came in last out of 5 (spun out), got beat by 70 ft. After this I looked to add weight. Turns out 1 rear tire had fluid and 1 didn't. Filled the other tire up with fluid, chained a cement block to the front (hanging low), sat on 16# of lead weights I found in my garage and weighed 2975# I finished 5th out of 7. Pulled 40' farther than the first time, and I totally powered out, with the front tires up about an inch. Seems like I've got the weight distribution good, just don't have enough power.
This brings me to a question, how does one get more power out of an N without spending a whole lot of money?
Steve
dave(47 8n)
08-12-2000 12:41:40
 Re: Re: 8Ns in pulling contests in reply to Steve, 08-11-2000 21:49:04
Sherman made an aluminum head for the N that gave ya more hp if ya can find one, also you can install a sherman or hupp tranny..this will give you more torque and power in first gear..
dave
Steve
08-15-2000 15:17:35
 Re: Re: Re: 8Ns in pulling contests in reply to dave(47 8n), 08-12-2000 12:41:40
I've been pondering the Sherman High/low transmission. How hard is it to put in and how easy are they to find, etc.? Also what kinds of ground speeds do ya get in low range? I'm gonna take it out this weekend to a 2 day pull in Banks Oregon generally one of the biggest in the area, I'm looking forward to it even if I don't place.
Thanks
Steve
Bob (KY)
08-11-2000 17:28:51
Seen something about this very thing not long ago on either this forum or in the Pulling forum. There is a guy that competes with an 8N and seems to do pretty good. Check the archives.
Scot
08-11-2000 13:56:04
In attending several local (Michigan) antique tractor pulls, the 2750# weight class that the 8N's have pulled in (only seen 2 compete) have been dominated by the small Farmall & Allis-Chalmers. I don't know if it's because they're cheaper to buy or more competitive? Of the 2 that I've seen compete 1 placed and the other didn't. The one that placed had smaller tires up front and a specially made hitch that connected to the 3-point and rear axle with skid for roll-over protection. It also had some weight slung from the belly, it was the one that placed. The other looked like it came straight from the field and did so-so but not good enough.
Does anyone out there have experience pulling with any of the N-Series? I too wonder because I have thought about playing some with my 8N powered 2N after it�s rebuilt.
Dave 2N
08-12-2000 18:48:04
 Re: Re: 8Ns in pulling contests in reply to Scot, 08-11-2000 13:56:04
I pull my 2N. Tires are loaded. Weighs less than 3500 so to be competitive in that class. I need to add weight. I do well against the smaller Farmalls and A-C's. Can't compete with lightened Super C's, etc. Never have spun out, always "Pooped out," Drawbar height important. Occasionally run into a pull that does it by the number of plow bottoms the tractor was designed for plus some common sense decisions by the director of the pull. He realizes that the N's got their traction from the weight of the implement or from the plow. I do real well in this class. It all depends....but they really take a little more work to make them competitive.
George
08-11-2000 13:52:34
I have noticed this in the past as well. I believe it has to do with the original design of the Ferguson System 3 point hitch, and the overall efficiency of getting the job done with less horsepower. Ford advertisements of the time made sales points of how inexpensive it was to plow all day with the Ford-Fergusons. Of course, later on bigger implements, live hydraulics, and saving time became more important. Seems if you want to really pull, get an Oliver. I'll stick with my economical 2N, thanks!
