3 point weak
chuck(wa)
08-10-2000 06:07:04
Last night I managed to get a tree between the
tire and box grader in other words well stuck.
Now the 3 point will not lift unless running at high rpm. As soon as I drop the engine speed, the implement drops too.
Suggestions?
chuck wa
08-10-2000 11:02:57
 Re: 3 point weak in reply to chuck(wa), 08-10-2000 06:07:04
Thanks, I got the tractor out last night, and the 3 point worked ok for a little while then the problem came up. Probably just coincidence but I was hoping I just knocked out an ajdustment
Dell (WA)
08-10-2000 08:54:19
Chuck..... .Disconnect your 3-point box blade and drive your tractor out. Then pull your box blade with a chain to get it away from the tree. DO NOT PULL FROM THE HANDY-DANDY TOPLINK POINT UNDER YOUR SEAT. It will cause your tractor to roll over on top of you with disasterous results.
Howsomever, if you are now unstuck, and your hydraulics still don't want to lift your blade, and assumeing that you haven't bent anything to cause binding. I would suspect that your hydraulic piston is leaking. Remove the inspection plate, thats the 6" round thing with the hydraulic dipstick in it. Look up inside and see where it is squirting. There have been many post concerning hydraulics, check the "archives" at the top of the page. Parts are readily available..... ..Dell
