2N Amp Meter Readings
Ed Varga
08-09-2000 19:59:56
Just had bearings replaced on the generator on my 2N's (6 volt pos. ground) generator which recently seized up. Now that I have it back on, at 3/4 throttle the ampeter reads at 20 to 25 + amps. Is this normal?
Also, how hot should the case of the generator get during operation?
Bill(NC)
08-10-2000 04:46:54
 Re: 2N Amp Meter Readings in reply to Ed Varga, 08-09-2000 19:59:56
There are guys on this board who are much more familiar with systems like yours (which sounds like original), but I'll give my 2 cents. After cranking the engine, the battery may be low, and it will charge at about 25 amps for awhile, but it should settle down to about 2 or 3 amps eventually. I don't think the generator should run hot; you may have a problem. I think there are adjustments that can be made to control the amount of charge the system will give.
Hopefully, someone will respond with more help. Good Luck.
Bill Malpass
