3-Point/Draft Control Problem????
Bobcat
08-08-2000 16:10:43
OK, where do I start? Well, I've got this �48 8N and the 3-point won't lift the tool (a blade) more than 2 inched off of the ground. I checked inside the inspection plate to see if the ram was leaking too bad. And to see if the pressure relief valve was bad. Well, the ram does leak, about 3 or 4 drops per second. The tool will remain up for some time after the engine is off. The relief valve has nothing coming from it.
However, if I remove the sheet metal control arm from the draft control and move the shaft further counter clockwise the tool will life very high and stay there. But, this doesn't happen with the sheet metal control arm inside the guide. It almost seems like the control shaft is a tooth off. Much like a distributor being a tooth off and you can't get enough movement to get the timing right.
What can I do. Can I realign the control shaft by reaching up through the inspection cover or do I have to remove the 3-point system altogether?
Bobcat
08-09-2000 16:36:43
 Re: 3-Point/Draft Control Problem???? in reply to Bobcat, 08-08-2000 16:10:43
Thank you everyone for your input. And thank you Zane for your e-mail about the jig. I've filed that in a folder I call "Keepers" for future reference. As you may recall from some of my earlier post, the tractor is not mine. It belongs to a cousin that I only see or hear from about every six months or so. He wanted to park it on my property and said I could use it when ever I wanted. Only thing is, I don't use something that I can't fix or afford to have fixed. I've ordered a service manual and parts book for the tractor.
There is more to this mess than meets the eye. The condition of this machine is a testament to the "keeps on Tickn'...." ability under extreme neglect. To top this off, the guy who worked on it last is a "magic" wrench. He was able to replace the clutch without knocking off any dirt from the bolt heads at the bell housing. He told my cousin that brake shoes could no longer be found for this 8N and had some shop re-weld the and re-line the old shoes. Seems a bit strange when I can find brake shoes with just a click of the mouse. Now the brakes make a terrible grinding noise and small pieces of felt have worked their way out of the drum. I'm not sure but, I think that ain't a good sign.
Anyway, thanks for the help.
dave(47 8n)
08-08-2000 17:01:12
to adjust loosen the 4 bolts on the yoke assembly and move the entire yoke back..if ya can't move it back far enough for it to lift within the quadrant then your position control pin needs replacing...
Dave
Steve IA
08-08-2000 16:16:41
Is your control arm bent? It shouldn't be. If it is you can't get a good adjustment. Get your FO-4 manual read the archives and pull the cover. Follow the instructions, check the cam follower pin and replace if necessary. Straighten the arm, adjust per the manual and you'll be amazed how nice a working 3 pt is. Good luck. Steve 8N 169302
