Order Ford 9N Parts Online
9N Shift Lever
Bri
07-23-2000 19:14:16
The shift lever on my 9N Tractor will lift right out . Is this normal and if it isn't can it be fixed? Thanks for the help
Tyler(MD)
07-24-2000 03:42:09
 Re: 9N Shift Lever in reply to Bri, 07-23-2000 19:14:16
You'll probably have to find a "shifter basket" at a boneyard or repair the one you have? (9N-7229)
That ball at the end of the shifter wears on the basket until the ball comes through it.
You'll have to remove the whole steering housing assy. which requires you to remove the hood and such.
third party image
Have fun,
Tyman
Matt Doyle
07-23-2000 21:35:52
No, it's not normal and yes, it can be fixed. There is a part that is worn out. I'm not sure exactly what this part is called or if the entire top tranny cover needs to be replaced to fix this. Stay tuned and I'm sure that someone with more 9N knowledge than I will respond.
