Order Ford 8N Parts Online
8N Hydralic pump problems
jeff
07-23-2000 11:39:49
My uncle and I just finished putting my grandfather's 52 8n after rebuilding the hydralic system. We replaced the piston and cylinder and took the pump apat, cleaned it and replaced the relief valve and one of the brass cam blocks that was cracked. Everything went back together fine, but when we started it the PTO made a couple revs then froze up. When we droped the pump to see what was wrong, we found that the front piston yoke, the same one that we replaced the cam block in, had shattered. Also, the left side plate that houses the valves was cracked. Can anyone tell me what could have gone wrong? Every thing seemed to go together great and was revolring fine before we put the pump back in.
thanks for your help.
