Order Ford 9N Parts Online
9n valve stem hole size and location
JWFritts
07-21-2000 22:06:51
On the advice of some fine fellow tractor owners I now have my 9n wheels all welded and ground smooth.But the previous owner had let the rust spot grow to almost one and a half inches either side of the valve stem hole.So I've never seen the exact location of the hole on the rim of the wheel.I also don't know the size of the hole although I could probably start off with a small drill bit and keep going to a larger size until the tube would fit. I would appeciate any advice.
Wick,De.
07-23-2000 06:27:17
 Re: 9n valve stem hole size and location in reply to JWFritts, 07-21-2000 22:06:51
I welded a washer of correct size after blasting the rim.Works great.
Tyler(MD)
07-22-2000 03:39:11
Both of your front wheels are like this?
Though I don't have a good closeup, I hope this will help:
third party image
I had to make a cold rolled steel plate with a hole in it and have it welded into the wheel. I ground off all the sharp edges. I don't remember the diameter of the hole on the original wheel.
Tyman
Gaspump
07-22-2000 09:30:26
 Re: Re: 9n valve stem hole size and location in reply to Tyler(MD), 07-22-2000 03:39:11
Nice posting work Tyman. The hole size is 5/8".
