3-point stabilizers
Ted Douglas
07-21-2000 11:39:17
I'm having a bit of trouble with the arms of my 3-point rubbing the tires and not staying centered. My stay chains are just the right length to allow full upward travel but they don't help with retaining the arms from their left to right sway. TSC has stabilizer bars that can be mounted on the rear axle, does this help or is there another solution?
Dale O'9N
07-21-2000 13:35:06
 Re: 3-point stabilizers in reply to Ted Douglas, 07-21-2000 11:39:17
Don't wait another moment. go get them. You can get by with just one, but get two for the heavy stuff. If your on bumpy ground they are like gold. Also a friend was plowing without them, and could not understand why the plow kept pushing to one side. He's getting them this weekend. If you plow, Do youself a favor. Get a center plow. It won't try to turn the tractor the entire time your plowing. Have fun, and please be safe.
Jim.UT
07-21-2000 12:59:03
Second Dell's motion. Worth every penny. Especially with those really heavy implements.
Dell (WA)
07-21-2000 11:59:38
Ted..... ...yes, absolutely, only solution. The stabalizer bars attach to mounting brackets held on by the fender bolts. The brackets have pins inline with your lower 3-point pins on differential, thus triangulating the lower 3-point arms preventing side sway, yet allowing the hydraulic lift arms to raise normally. Get 'em..... ....Dell
Dave 2N
07-21-2000 18:33:43
 Re: Re: 3-point stabilizers in reply to Dell (WA), 07-21-2000 11:59:38
No N should bewithout them.
