Order Ford 9N Parts Online
9n, 3point, Zane thang
Mike
07-21-2000 06:35:26
Howdy!
I was messing around with the 3 point, grading the driveway, and tried to get the blade to stay in one spot, it either stays up, or down, inbetween, it slowly goes down. If I try to lift it a little, the whole thing "bounces" with every firing of the engine. Is this what the Zane thang is for? Will it keep it in place no matter what? I also bent the crap out of the leveler crank when I went on a slight hill. ...Mike
ZANE
07-21-2000 19:27:59
 Re: 9n, 3point, Zane thang in reply to Mike, 07-21-2000 06:35:26
If you would like to learn more about the position control device just look at the link listed below. It is my web site.
Jim.UT
07-21-2000 07:57:27
You are correct! That's exactly why all the 9n/2n owners are raving about the Zane Thang. After putting up with what you are experiencing for 60 years, they finally can put the lift where they want it and have it stay there.
Dean Sparks
07-21-2000 09:21:25
 Re: Re: 9n, 3point, Zane thang in reply to Jim.UT, 07-21-2000 07:57:27
Where do we order the Zame Thang? I need one--I'm trying to plow a 9 acre field with a single bottom plow and the 9N and it keeps moving up and down and all over the place! Someone please help! Thanks.
You don't want a Zane Thang - llamas
07-21-2000 09:29:01
 Re: Re: Re: 9n, 3point, Zane thang in reply to Dean Sparks, 07-21-2000 09:21:25
for plowing. You want the "draft control" function built into your hitch, to maintain a constant draft.
If the plow is bouncing up and down, your hydraulics need adjusting or servicing.
Don't get me wrong, I have a Zane Thang, it's an inspired solution for position control, and I recommend it highly for that purpose. But not for plowing.
llater,
llamas
Dean Sparks
07-21-2000 09:21:00
