3 Brush Generator
Bill(Tx)
07-13-2000 11:08:23
Would the generator bracket that attaches to the front 2 cylinder head bolts be the same type used on 9N's? I'm looking to correctly restore the generator mounting for 1941. See pic.
llamas
07-13-2000 11:53:26
 Re: 3 Brush Generator in reply to Bill(Tx), 07-13-2000 11:08:23
The set-up in your picture is correct for a third-brush generator. The tensioner assembly is correct, although I can't see the castle nut and cotter pin.
llater,
llamas
Old Ag
07-13-2000 13:59:34
 Re: Re: 3 Brush Generator in reply to llamas, 07-13-2000 11:53:26
I didn't know about the tensioner set-up. What's it called and where do I get one?
Thanks,
Old Ag
Old Ag
07-13-2000 11:39:33
Bill,
I just put a 3-brush generator back on my '41 and the only thing holding it on are the brackets on the bottom (on top of the governor). N-board members convinced me that was the proper set-up, but I sure had to torque the "you-know-what" out of that bolt to get the generator to hold tension against the belt. I do like that nifty tension bolt/bracket on top of yours though, like the vent holes in the generator too.
By the way, if you can explain how the 3rd brush powers up the field windings feel free to tell me all about it. I'm stumped on that one.
Old Ag
'41 9N
Claus
07-13-2000 12:49:08
 Re: Re: 3 Brush Generator in reply to Old Ag, 07-13-2000 11:39:33
Ok, lets start with the 2 brush generators. On the 2 brush generator the field is powered by connecting the high side to the armature and the low side is connected either to ground through the regulator or a resistance in series to ground. In the 3 brush generator, the high side is connected to the commutator via the third brush. Each segment further away from the output brush the voltage is lowered some. This is done through the adjustable brush. The low side of the field is always connected to ground. This does not afford any regulation but the output can be lowered somewhat in an attempt to keep the battery from overcharging. Obviously this system left a lot to be desired and the introduction of the voltage regulator was a quantum leap.
Happy Motoring
Claus
Old Ag
07-13-2000 13:56:40
 Re: Re: Re: 3 Brush Generator in reply to Claus, 07-13-2000 12:49:08
Thanks for the info, but I don't see how you have a complete circuit? I was thinking there were two commutator segments for every armature winding. The + and - poles are 180 degrees from each other, and that explains why the positive and negative brushes are located on opposite sides of the commutator to complete the circuit through the armature windings. For the field, there's only one brush in contact with the commutator and nothing 180 degrees out. So the circuit would seem open, right? It would be like disconnecting the ground on a battery and hooking up a load to the other terminal, nothing would happen.
I am definately not an expert on DC machines, just looking for somebody to set me straight. Thanks!:)
Old Ag
Claus
07-13-2000 14:32:53
 Re: Re: Re: Re: 3 Brush Generator in reply to Old Ag, 07-13-2000 13:56:40
The low side of the armature is grounded through a brush as where the low side of the field is grunded through a ground connection. The armature is wound like taps on a transformer (many) Your paradigm is that all windings are seperate.
Happy Motoring
Claus
Old Ag
07-13-2000 18:52:09
 Re: Re: Re: Re: Re: 3 Brush Generator in reply to Claus, 07-13-2000 14:32:53
Thanks Claus! Obviously, I've got me some book readin' to do on DC machines.
Thanks again.
Old Ag
