Lift leaks
Billy
07-13-2000 09:15:42
Doe's anyone know of some type of add on tooling to keep the lift from leaking and mohawking my yard basically all I do is mow 7acres but would like tooling to be easy to remove.
llamas
07-13-2000 11:57:01
 Re: lift leaks in reply to Billy, 07-13-2000 09:15:42
The 8N lift, in position-control mode, will correct for a fair amount of leakage. If yours is not doing so, either the control linkages need adjustment/repair or it's leaking real, real bad. Either way, you might be better served to repair the lift.
If you accidentally have it in "draft control" mode, it will leak down and not compensate, so I'd check for that before anything else.
llater,
llamas
Ed Gooding (VA)
07-13-2000 11:04:18
Hi Billy: If you want to make your own limter chains, refer to the following link to a past article with the instructions by clicking on the link here: Click here to get written instructions
and refer to the two drawings below on how to make them and how to install and use them:
third party image
third party image
Hope this helps..... ..... .....Ed
'52 8N475798
Claus
07-13-2000 09:46:58
Don't quite understand what you are talking about. Guessing, do you have a mower that only has 2 rear wheels that you keep the front up with the lift? If so, you can get limiter chains. They are reasonably inexpensive. See one of our advertisers for these.
Happy Motoring
Claus
Billy
07-13-2000 10:20:45
 Re: Re: lift leaks in reply to Claus, 07-13-2000 09:46:58
Claus, you are partially right I have one wheel on my mower. It is an 8-n 1950 model, but could you be alittle more specific on the advertisers thanks Billy.
Mark *8N126975*
07-13-2000 10:56:01
 Re: Re: Re: lift leaks in reply to Billy, 07-13-2000 10:20:45
There are lift arm seals. I'm not sure if you are saying fluid is leaking around the lift arms themselves or if the arms are simply drifting down.If they are just drifting down, you have a leak in the hydraulic system that might be 1. the piston and gasket with O-ring 2. An internal leak on the upper or lower gasket
3. Relief valve. I recommend a video from J&D Productions, Inc. on Hydraulic Overhaul repair and troubleshooting.
P.O. Box 38
Metamora, MI 48455
You can do an overhaul yourself for around a $100
in parts.
D.Brookins
07-13-2000 10:54:25
Yeah Claus,you need to be a little more specific on your answers.
D.Brookins in Atoka.
Claus
07-13-2000 13:10:04
 Re: Re: Re: Re: lift leaks in reply to D.Brookins, 07-13-2000 10:54:25
So solly. See Mr. Gooding's fine description above. For the non-do-it-yourselfer, these can be purchased from one of our suppliers for small chump change...
Happy Motoring
Claus
Billy
07-15-2000 05:58:44
 Re: Re: Re: Re: Re: lift leaks in reply to Claus, 07-13-2000 13:10:04
Thanks guys,all the information was alot of help, I have an item that will do the same as the chain only it will give 1/8" increments over 3/4" increments that the chain offers. I'm presently working on my First web. page.I've been looking at this forum for some time and I think it's great . I've also got a kit for the lift which will let you controll the height of mowing,box blading etc.
