Order Ford 8N Parts Online
8N Starter Trouble
Ken (MO)
07-13-2000 05:35:55
The starter on my '52 8N has developed the nasty habit of grinding away most times I try to start it. I checked the flywheel through the timing opening and can see that when the starter is grinding the flywheel is not spinning (BTW the flywheel teeth look pretty good). If I put it in 4th and rock it a bit, I can get the starter to engage and she fires right up. I tried charging the battery (6V) thinking it may not have the juice to really throw the starter gear out but that didn't seem to help. What's next?
rbell
07-13-2000 06:19:22
 Re: 8N Starter Trouble in reply to Ken (MO), 07-13-2000 05:35:55
Got a long nozzle for your can of WD40? If you can reach the bendix assembly and shaft spray them good! I have seen situations where "stuff" built up on the shaft and the bendix was sticking.
TimK
07-13-2000 06:17:25
You probably are have trouble with the bendix drive engaging. That's the part on the end of the starter that is spring loaded and engages the ring gear when you start up, and disengages after the flywheel reaches a certain rpm. The bendix should be dry. Sometimes oil and grit gets into it and fouls up its function. Suggest you clean the bendix with solvent real good, let it dry, and try it again. Also, there have been cases where the ring gear has become loose on the flywheel, and when the starter engages, it just spins the ring gear and not the flywheel. Put a chalk mark on the ring gear and the flywheel to make sure the gear is not slipping. If the cleaning doesn't work, I think a new bendix is in order.
