Order Ford 9N Parts Online
9N running problem
Don
07-08-2000 06:19:06
Just had my 9N completely overhauled, runs great until it gets hot then dies, misses a minute or so then dies. It will not start with the starter but can pull it 2 feet and starts right up. I suspected mag/coil/distributor had those checked with no problems. Great running when its cold or when the weather is cool. Any ideas, sugestions, etc. The mechanic I hired to do the overhaul has been working on N's for 40 years and he has no answer. Looking at some of the other forum topics I have to admit that this problem did not exist before the overhaul. What might we have done to cause this? I feel sure the problem is electrical but one farming neighbor thinks its gas related, vapor lock? Thanks to any suggestions, I need my haying tractor to run as I'm tired of walking home from the field.
Dell (WA)
07-08-2000 07:13:15
 Re: 9N running problem in reply to Don, 07-08-2000 06:19:06
Don..... ..ya' gots 2 interrelated problems.....
"will not start with the starter but can pull it 2 feet and starts right up"..... weak battery, re-charge won't really solve the problem as your "plates" are loaded up. New is only real solution. Reason: it only takes 3 amps to run the ignition system and your battery can supply that much but it takes about 50 amps to turn the starter and when it does that theres is not enuff plate capacity left to run a bad ignition coil.
"runs great until it gets hot then dies"..... bad frontmount ignition coil. Reason: When coil gets hot, some of the turns short out because the insulation melts. Unfortunately, frontmount ignition coils are not the most roboust anymore and the only real test is by replacement. Bite the bullet.
One of the original N-Board contributors claimed 90% of all carburator problems are solved in the ignition system. Food for thought. Because the N-Tractor gas system is gravity fed, vapor lock is usually not a problem. But check all 3 fuel filters for clogging anyways (including the one in the carb elbow).
Hope this helps..... ..Dell
Don
07-12-2000 08:24:06
 Re: Re: 9N running problem in reply to Dell (WA), 07-08-2000 07:13:15
Thanks Dell!
You nailed it with the coil. New one is in place and problems gone. Sure appreciate your help, and the forum to provide access to experienced advice.
