Order Ford 8N Parts Online
8N electrical help needed please
Joe
07-04-2000 08:35:08
I am rewiring my 1949 8N (serial 169650).
1. Does the wire to the ammeter need to be stripped, or does the ammeter act like an amprobe, and does not need to touch the bare wire? The new wiring harness has a normal insulated wire plus a plastic sleeve in this area. The old wire that I removed was very brittle and it looked like it may have been stripped, but I am not sure.
2. My resistance block has a fourth wire going from the lower terminal to a small block that has a glass tubular fuse. This small block is mounted directly under the voltage regulator. What is this for? (the other three wires on this terminal are: 1. the above mentioned wire that comes from the starter relay through the ammeter, 2. the key switch wire, 3. a wire to the regulator)
I appreciate all the good advice that appears on this webpage. I have my 8N almost reassembled after an engine overhaul. I hope it starts. So far there are no extra pieces laying around.
Steve IA
07-04-2000 09:23:37
 Re: 8N electrical help needed please in reply to Joe, 07-04-2000 08:35:08
Joe ask: My resistance block has a fourth wire going from the lower terminal to a small block that has a glass tubular fuse. This small block is mounted directly under the voltage regulator. What is this for? Is there a pull/push button on the driver side of the small block? If so it is a light switch.
HTH
Steve
Joe
07-04-2000 10:14:33
 Re: Re: 8N electrical help needed please in reply to Steve IA, 07-04-2000 09:23:37
Steve: All I had to do was open my eyes and I could have seen the light switch. I was on the other side looking back toward the seat and didn"t bend over to see the dumb switch right in front of me. Thanks. Sorry to waste everyones time on this one.
Joe
07-04-2000 14:28:18
 Re: Re: Re: 8N electrical help needed please in reply to Joe, 07-04-2000 10:14:33
Happy Day!!!
I just finished putting everything back together after a major engine overhaul. First crank, it fired but wouldn't run because the carb was not full yet. Second crank, ditto. Third crank it fired and kept running with no adjustments to the carb or anything else. I noticed one oil drip from the fitting on the bottom of the oil filter that I had just finger tightened. I fixed that and am back in business ready to cut some weeds. Once again, I appreciate the good advice that I picked up from this forum along the way.
I found out if I just search the archives, almost every question is already answered. But, I appreciate everyone's patience to keep answering anyway. Thanks!!
Bob (KY)
07-04-2000 08:47:12
Hey Joe, Try the following link and see if that helps. It has 6 and 12 volt diagrams for Ford Tractors.
Tom Harrower
07-04-2000 23:31:52
 Re: Re: 8N electrical help needed please in reply to Bob (KY), 07-04-2000 08:47:12
Thanks Bob, for posting that link. Allways nice to find some good information out there. If anyone needs a good diagram for a 12 volt conversion using a delco 10si alternator, let me know.Someone was nice enough to send it to me when I was doing the conversion, and I'd be happy to share it if needed.
