2N drag link end replacement
Bob (KY)
07-02-2000 10:30:01
The drag link end (@ steering sector) is badly worn. What is recommended way to replace? Does the drag link have to be replaced or can the end be cut off and weld a new one in place. Looking for suggestions.
Thanks fellas!
Claus
07-03-2000 05:29:17
 Re: 2N drag link end replacement in reply to Bob (KY), 07-02-2000 10:30:01
This depends on your wallet and other considerations. If it is a working tractor, then you may want to weld a new end on. The long rear drag links are no longer available. They are replaced with a long adjustment tube and a short rear tie rod end. The tube cost about $30 to $40 depending on where you buy it. I paid $40 at NH Dealer.
