2N cranking
Dave2N
06-26-2000 07:03:54
Need some help and advice guys: My 2N turns over and starts on a cold start. If it's been running and it's hot, it will barely turn over. The cable and post on the starter get really warm. Had a new drive last fall and if I recall correctly, they said that everything else in the starter checked out OK. I've cleaned all connections twice but no difference. What shuld I try next?
Thanks.
Bob [ME]
06-26-2000 18:02:05
 Re: 2N cranking in reply to Dave2N, 06-26-2000 07:03:54
Another possibility is a bad field coil in the starter. Failure of the starter motor to crank over when hot is a classic symptom of this problem.
erik
06-26-2000 10:38:48
The cable coming from the battery to the starter should be 0 or 1 guage (the ground cable should also be). This may be the problem. 0 and 1 guage is hard to find: the thickest you can get easily is 2 guage whitch isn't heavy enough for a 6 volt system.
erik
06-26-2000 10:38:38
Jim.UT
06-26-2000 14:54:55
 Re: Re: 2N cranking in reply to erik, 06-26-2000 10:38:38
My NH dealer has the 00 copper cable in bulk and all the terminal ends needed. I took my old skinny cables and said "make me some new ones this long with these terminals out of your 00 cable". It was a little pricey, but I had them the same day.
