Just saved myself a couple thousand dollars
Elwood
06-16-2000 16:50:28
third party image
I fixed that leaky fuel line for the last time.Finally took the advice of a couple of unfortunate people on this forum who lost their tractors to a fire.The fuel line tended to develop a leak a couple times a year and had to be tightened.Paid $14.00 for the correct line which seems to be great plenty but is cheap compared to the risk I was running of a fire.I took this hazard for granted for years and thank those of you who pointed out the danger of a patched in line fuel filter.
EZ8NCA
06-16-2000 17:18:50
 Re: Just saved myself a couple thousand dollars in reply to Elwood, 06-16-2000 16:50:28
So Elwood where did you by the line and does it come with the filter?
Thanks
EZ8NCA
Elwood
06-16-2000 18:20:27
 Re: Re: Just saved myself a couple thousand dollars in reply to EZ8NCA, 06-16-2000 17:18:50
Got mine from my good friends at Tractor Land Inc. It is like the original fuel line and has no filter.The fuel sediment bowl and screen do a good enough job as long as your fuel tank is clean and so is the fuel you are adding.
