2N Resistor/Terminal Block???
Bob (KY)
06-11-2000 17:49:17
Inside the dash, on the left side, there is a terminal block w/ a resistor. Can this part be obtained OEM or is there an automobile part to replace it that I can get from NAPA or other auto parts store. The tractor will not start unless I hot wire around it. From what I've seen in the archives running 6 volts to the coil will fry it and the points. Thanks in advance for your help.
Gord - with a hard working 9n
06-12-2000 18:22:11
 Re: 2N Resistor/Terminal Block??? in reply to Bob (KY), 06-11-2000 17:49:17
Sparex makes a complete 9/2/8n 12 volt conversion kit complete with mounting hardware, alternator, belt, wiring harness and 12 volt coil. This installs reallty easily, and uses the existing 6 volt resistor. I got mine at my local New Holland dealer....works great!
Gord
big g
06-12-2000 11:39:47
try cliking on "parts annd supplies" at the left side of this page. Look for "resistor".
