Order Ford 8N Parts Online
8N Clutch Problem
Jonathan del Va
06-09-2000 20:23:01
I just finished replacing the thrust bearings in the steering wheel on my 1949 8N. After I completed reassembling everything, the tractor started fine. However, after puting it into gear and releasing the clutch pedal, it didn't move.
I'm new at this. So, I don't know if I touched something related to the clutch when I took off the dashboard, hood, steering wheel, etc.
Can someone give me any ideas on how to troubleshoot this problem?
Thank you.
Jonathan 8NIL
ron
06-10-2000 14:36:04
 Re: 8N Clutch Problem in reply to Jonathan del Valle, 06-09-2000 20:23:01
you need to check see if lever going in bell housing free also make sure you have it in netural when checkit also coulping betweeen
trans and diff that breaks usualy breaks plow snow i work ford tractor dealer for 18 yrs
Jonathan
06-11-2000 08:58:10
 Re: Re: 8N Clutch Problem in reply to ron, 06-10-2000 14:36:04
Thanks for your reply. The problem was with the lever in the bell housing. It moves now!
