Order Ford 8N Parts Online
8n suddenly dies after 20 min. of operation
Lou
06-08-2000 18:26:56
I have an 8n. I think it is a '51. It has an angle drive distributor. It starts fine and runs good for a fixed amount of time, about 20 to 30 mins. It suddenly quits. At first I thought it was fuel related because I had recenly rebuilt the carburetor. Now I suspect it may be related to the electrical system. That perhaps it occurs when the something reaches a certain temperature. I replaced the coil. That did not solve the problem. I was told to replace the resistor assembly but my tractor is after serial no. 263843 and it does not have that assembly. Has anyone encountered this problem?
ed adams
06-11-2000 12:59:48
 Re: 8n suddenly dies after 20 min. of operation in reply to Lou, 06-08-2000 18:26:56
i just had that prob. it was my fuel.i tried to do an improvement by adding an in line fuel filter.i would run about 15-20 min. and die.took it off and now alls fine.fuel was restricted,it was using it faster than the bowl could fill up .hope this helps
ron
06-10-2000 14:47:12
i work at ford tractor dealership for 18 yrs
there it could be lot thinks coil fuel tank valve plug up or. is it 6 or 12v lots people change then to 12v you also need change coil to 12v
tank vale need un screw out tank or replace it it get plug up after you use it a short time then unplug it self also install new coil and cond
Rusty 2N
06-08-2000 20:50:24
If you got a condeser, replace with a known good one & if this works look for a bare wire going to dist.
bg
06-08-2000 19:11:23
I agree with Mike. It could be the switch...but if it will start again after it cools off, I'd suspect the coil. Even new coils can be bad out of the box. Also make sure the small primary wire from the coil to the distributor base is not grounding out on the terminal. The little insulator where the terminal goes through the distibutor housing can go bad.(Probably not the cause of your problem, but worth investigation)
Snow Plow
06-09-2000 19:50:55
 Re: Re: 8n suddenly dies after 20 min. of operation in reply to bg, 06-08-2000 19:11:23
I agree with Bob. Sounds like a coil. Get a wiring diagram and go through each section checking for problems. It is a pretty simple set up, only a few places things can go wrong. The 20 min time suggests heat and then electrical failure. Classic coil problem!
Good Luck!
Wayne
06-08-2000 21:08:26
Absolutely. Bought a new coil for my 49n. It would hardly run with old one and not at all with the new one. The dealer tried to convince me the coil was good. Finally he exchanged it and the tractor runs so well and sweet I could of cried out of happiness
Mike OH
06-08-2000 18:55:42
You will need to do some checking the next time it quits. Check to see if you have spark at the plugs. If you do, check to see if you have gas flow to the carb. That will tell you in which area the problem lies. I had a bad ingition switch at one time that gave me fits until it was replaced. HTH. Mike
