Battery/Jump
Colby Hill
06-08-2000 13:02:02
A couple of days ago, I posted a message about a positive ground battery vs a negitive ground battery. Now I have a related question. If I have a positive ground battery, how do I jump it? Is it the usual NEG to NEG? Or is it NEG (live battery) to POS (tractor battery)? Excuse my ignorance. Thanks in advance
Jim.UT
06-08-2000 14:48:45
 Re: Battery/Jump in reply to Colby Hill, 06-08-2000 13:02:02
To avoid frying electrical components you should bypass everything but the starter when jumping a positive ground 6V battery. If you do, you can use a 12V battery to jump start your tractor. When this method is used polarity doesn't matter. Here's how to do it step by step:
1. Shift tractor into NEUTRAL. This is very important because this method bypasses the neutral safety switch.
2. Turn key on. This method assumes the tractor battery has enough juice to fire the spark plugs.
3. Attach one jumper cable to a good ground on the tractor frame.
4. Touch the other cable to the terminal on the starter where the cable from the solenoid attaches. The starter will immediately start to spin and since you are probably standing next to the tractor at this point, you see the importance of step 1. You don't want that big ol' rear tire on any part of your anatomy.
Good luck.
Snow Plow
06-09-2000 19:55:24
 Re: Re: Battery/Jump in reply to Jim.UT, 06-08-2000 14:48:45
I agree with your post however consider attaching to the starter post first and then hitting the fram with the second. If you get an arc on an unimportant area such as the running board who cares. But a gooked up starter post could be a pain. Good Luck!
I stand corrected........Jim.UT
06-09-2000 21:33:42
 Re: Re: Re: Battery/Jump in reply to Snow Plow, 06-09-2000 19:55:24
Good catch! :)
Ron(WA)
06-08-2000 13:46:06
Neg to Neg, Pos to Pos
