It was a bad coil all-along
TexasJim
06-06-2000 09:25:50
Finally got my '41 9N up and running.
I started with a problem of intermittent spark after I left the key in the ignition for a long time. I made my tractor a non-starter.
Then I checked the points, plugs, etc. everything I could think of and narrowed it down to the rotor button or the condenser, so I thought. Then after breaking down and replacing the coil, the old tractor fired right up. Sure would have helped to test that coil at the get-go, but no place I went to could check it for me.
Lesson Learned. Key left in, intermittent spark, non-starter ----> might be the COIL!!!
Big Jake
06-06-2000 09:53:56
 Re: It was a bad coil all-along in reply to TexasJim, 06-06-2000 09:25:50
check this link out!!
http://www.fluke.com/application_notes/automotive/ignition.asp?AGID=1&SID=103
JR
06-06-2000 09:50:10
You do mean key left "on"?
TexasJim
06-06-2000 18:31:53
 Re: Re: It was a bad coil all-along in reply to JR, 06-06-2000 09:50:10
Yep. That's what I mean. Key was left "ON" for a long haul road trip. I don't know if that was a contributing factor to the coil failure, but the tractor worked fine before the trip.
