Left parking brake sticks
Mike B IL
12-19-2002 06:58:28
I went to move my N last night and noticed that my left tire was dragging. The lever for the parking brak somehow got set.
I do not use the left side "parking" brake as there seems to be something missing. It does not set like the right side.
Would somebody post a picture of the left side "parking" brake set up so that i may see what is missing or set wrong.
Thanking you all in advance!!
Mike
Mike B IL
12-19-2002 10:57:52
 Re: Left parking brake sticks in reply to Mike B IL, 12-19-2002 06:58:28
Dale M hit it right on the head! This is why I do not use the left side brake. My problem is that I must have used the left brake and the brake prawn engaged by itself. I don't want to take it off but I would like to fix it so it does not lock on by itself.
Dale M
12-19-2002 09:18:03
Mike, my right one on my 8N disengages by gravity when I push down on the peddle. The left one seems to always need disengaged by hand - gravity doesn't seem to do it. Put it on tight enoough when you use it to make sure it apparent when you go to drive away. Don't think there is a spring.
Soundguy
12-19-2002 07:56:02
Well, at least your breaks work... I can only lock up my right one.. my left one barely works.
If'n you can lock yours up you got braggin rights.
Soundguy
Hyd. Leak ?
12-19-2002 08:00:33
 Re: Re: Left parking brake sticks in reply to Soundguy, 12-19-2002 07:56:02
Soundguy, sounds as though you may have been hit with the infamous 8n rear axle leak on that other one, huh ?. Dale-PA
Soundguy
12-19-2002 12:06:52
 Re: Re: Re: Left parking brake sticks in reply to Hyd. Leak ?, 12-19-2002 08:00:33
It doesn't leak now, But I believe it did for the previous owner, as he stated he had replaced some seals, and also had the pto changed over earlier in it's life.
The shoe engages ( I can feel that much.. but doesn't bite down good like the other side, and I think, like you point out, that it is due to an old oil saturated shoe. )
I guess if I look on the bright side, that drum ought to be very shiny anf hi-polished!
Soundguy
Dale-Pa
12-19-2002 07:44:26
Mike, Your parking brake is actually a brake "pawl". Has teeth on one side that mesh into teeth on the tractors casting. Is this "engaged" or stuck, or is it internal ? Braking system. If its internal, try rocking the tractor forward/reverse)to free the system internally, sometimes they will bind depending on usage/weather. If persists, get into the braking system and find the problem.
Mike B IL
12-19-2002 07:48:55
 Re: Re: Left parking brake sticks in reply to Dale-Pa, 12-19-2002 07:44:26
I filpped the lever off and it worked fine. It seems that maybe a spring is missing. It does not like to set, so I do not use it. I would like to make it right though.
