Order Ford 8N Parts Online
52 8N 3PTH AXLE PIN Broken Off HOW TO REPLACE ???
Bill BC
12-14-2002 23:05:36
The large Pin on which the lower bar of the 3PTH attaches to the rear axle is sheared off. (ambitious logger)
The one on the other side of the axle is good.
The local Tractor supply fellow thought this large pin bolts on from inside of the axle ?? Also he thought that Part # was the same as a 9N, but the 9N appears to to have an extra plate attached, so I have my doubts ??
Any Suggestions ??
Patrick Md. Va.
12-15-2002 05:16:39
 Re: 52 8N 3PTH AXLE PIN Broken Off HOW TO REPLACE ??? in reply to Bill BC, 12-14-2002 23:05:36
third party image
This is a picture that someone posted a good while back.
duey
12-15-2002 12:27:16
 Re: Re: 52 8N 3PTH AXLE PIN Broken Off HOW TO REPLACE ??? in reply to Patrick Md. Va., 12-15-2002 05:16:39
Patrick, that is a picture from my 2N (1946)... I don't know if there's any difference internally for the 8N....duey
Patrick Md. Va.
12-15-2002 13:18:47
 Re: Re: Re: 52 8N 3PTH AXLE PIN Broken Off HOW TO REPLACE ??? in reply to duey , 12-15-2002 12:27:16
I save internal pics. You never know when you may need to look at how something goes. I saved that pic because i also have a 2n. I also do not know how the inside of an 8n compares.
Ken N Tx
12-15-2002 02:59:53
Yes it is bolted from the INSIDE, you have to take the Trumpet off to get at it...My manual shows part #NCA563C it is called a Lower link Support Shaft...Ken N Tx
Picture...Shaft...Ken N Tx
12-15-2002 03:49:42
 Re: Re: 52 8N 3PTH AXLE PIN Broken Off HOW TO REPLACE ??? in reply to Ken N Tx, 12-15-2002 02:59:53
third party image
Here is a picture Willy N posted..
bg
12-15-2002 13:50:55
 Re: Re: Re: 52 8N 3PTH AXLE PIN Broken Off HOW TO REPLACE ??? in reply to Picture...Shaft...Ken N Tx, 12-15-2002 03:49:42
The new pins you get from NH will probably not have the recess in the taper. The taper will be continuous.
Willy-N Those were 8Ns here is the 9Ns link mount
12-15-2002 07:30:47
third party image
Here is a set of the 9N mounts but they still bolt on from the inside of the trumpit with 1-bolt and a bolt on the outside. Mark H.
Ken N Tx
12-15-2002 07:55:06
 Re: Re: Re: Re: 52 8N 3PTH AXLE PIN Broken Off HOW TO REPLACE ??? in reply to Willy-N Those were 8Ns here is the 9Ns link mount, 12-15-2002 07:30:47
He said he had a 52 8N....My 2N has what you show for a 9N, but the plate and bolts are seperate...The bolt goes thru the plate...Are the ones you show one piece??? Left and Right ??? Ken
Willy-N
12-15-2002 08:02:15
 Re: Re: Re: Re: Re: 52 8N 3PTH AXLE PIN Broken Off HOW TO REPLACE ??? in reply to Ken N Tx, 12-15-2002 07:55:06
Sorry about that I had just woke up when I posted that! The stud could be knocked out from the plate I guess but mine came out all together and I left them that way. Yes they are right and left ones but both are the same. I had to remove these to replace the gaskit and reseal them. Mark H.
