Installing valve guide seals
Dan J ( How to
12-13-2002 16:27:40
After much wrestling with the valve guide seals that go on the intake guides of the 8N & 9N I figured out a fairly painless way to get them on. Thought I would share. Oil the seal and lay one edge into the slot it is supposed to go into and clamp in a vise (gently)so the back jaw of the vise holds the seal in the slot. This makes a loop out of the seal that is parallel with and pointing toward the top of the guide. Now take a medium flat screwdriver and go thru the back of the loop of the seal with the screwdriver pointed toward you and catch the near side of the guide with the tip. Pull the screwdriver toward you until it stretches the seal all the way across then just push the sides of the seal around the guide. Seal usually goes in turned but easy enough to straighten out. Easier to do than to explain. Dan J
