2n steering question
sean
05-31-2000 15:44:59
i justed replaced both sector gears and pinion.
this has corrected all problems, but i notice that when i turn the steering wheel all the way to the rt.,the rt wheel goes sharper and further then the left. but always returns even at mid straight ahead steering. have i over looked an alignment procedure of the gears or is this just the way it is designed?
Claus
06-01-2000 04:45:43
 Re: 2n steering question in reply to sean, 05-31-2000 15:44:59
Look at the sector arms when you have both wheels straight ahead. They should both be slightly to the back (About 5 o' clock position) this gives you the desired toe out on turns.
Happy Motoring
Claus
Jim
06-01-2000 03:37:37
Check your steering arms on the spindles for length. The original arms had a taper/bolt locking system and were a little longer than the later versions that used a clamp bolt and key. That would make one wheel go further than the other if you have one of each.
