Hi Gary, There are certainly more tractor tech�s on this board that are more experienced than myself, but I will attempt to help you. One of your statements was a red flag to me. You said, �I put a volt ohm meter from the negative side, which is set up as a negative ground, and the feed side of the solenoid to the starter and I get no voltage�. To me, this would indicate that you are somehow not getting voltage to the line side (battery side) of your solenoid. You can take one conductor of a jumper-cable and jump from the line side (battery) of the solenoid to the load side (starter) (make sure tractor is in neutral). If nothing happens, you are not getting voltage to the starter through the solenoid. The solenoid is simply a switch that, when energized through the starter switch, closes a circuit to the starter motor. If the starter motor turns over good when jumped, then you need to double check everything to make sure you are getting full voltage at the solenoid and the solenoid is indeed good. Another test you can try is to take the jumper-cables and connect one end of the black cables to the �ground� post on the battery, the other end of the black to the starter casing/housing/bolt ends. Then take the red cable and connect one end to the �hot� side of the battery post and use the other end to energize the starter at the load side of the solenoid or the hot post on the starter. (Make sure tractor is in neutral) If the starter motor cranks the engine, you have a problem from the battery to the solenoid. HTH. Rick H. Ga.
