Order Ford 8N Parts Online
1951 8N No Oil Pressure
Bill(NC)
10-07-1998 19:07:39
I started my tractor today and it had no oil pressure. Sounded a bit loud. I didn't keep it running long. It had been sitting about a week since the last time I used it. Then it had about 35 lb pressure cold and 15 lb hot and was running very well. I had put a new spring in the pump.
Today, I disconnected the oil line at different places, and got hardly any oil out with the engine running briefly. I pulled the spring/plunger out and they looked OK. I drained the oil and checked the screen and foot and they looked OK.
Anyone have an idea? Bad oil pump?
E.Allison
10-08-1998 07:03:02
 Re: 1951 8N No Oil Pressure in reply to Bill(NC), 10-07-1998 19:07:39
It's possible your pump has lost its prime. Did you ever have oil pressure after the spring replacement? Does the new spring seem to force the ball against its seat? I would try removing the oil line that feeds the oil filter and using a hand-pumped oil can to shoot a pint or so of oil back into the engine through the line. If it has lost prime, this may restore it. EEA
dave#1
05-31-2000 04:18:57
 Re: HYDRAULIC OIL LEAK ON 2N in reply to BIGDOG, 05-30-2000 06:24:27
third party image
Here's a pick of my 50 8n, you can see the nut that holds the lower pin, the pins on the 8n are tapered, yours are not. Be carefull when removeing the axle houseing,the differental may want to come out with it and it's heavier than a truck load of coors lights!(-: As far as the axle seals, JerryU used those "Sure seals" and said they worked great.
hope this helps.
later,dave
