.5 ohm resistor
Eddy
12-05-2002 10:40:35
Just wondering where everyone that has one of these trick resistors mounted them on the tractor? I was thinking of digging the old coil resistor out and using its connectors for the new resistor. Any other ideas?
Dell (WA)
12-05-2002 10:47:49
 Re: .5 ohm resistor in reply to Eddy, 12-05-2002 10:40:35
Eddy..... ...thats one good place if you're clever and the terminal mounting block isn't cracked or broken. (it happens)..... ..Dell
DavidO
12-05-2002 12:02:50
 Re: Re: .5 ohm resistor in reply to Dell (WA), 12-05-2002 10:47:49
Just be sure to mount it somewhere that air can circulate around it. DON'T mount it inside a wiring harness all wrapped up or next to any wires that might be damaged from the heat from the resistor.
