Order Ford 8N Parts Online
8N still won't start
garth(IA)
11-28-2002 11:09:54
I posted a couple of days ago about my 52 8N not starting. Have spark, gas to carb. It was suggested that I try some starting fluid and/or cover the air intake on carb while starting. Neither of these made any difference. When I pull out the choke while turning over the engine, the carb backfires gas out the air intake. Any suggestions to get my N running again?
happy thanksgiving.
Fast Ed Ohio
11-28-2002 22:46:00
 Re: 8N still won't start in reply to garth(IA), 11-28-2002 11:09:54
Its easy to get the plug wires on wrong ( should be 1243 ) point gap can also cause problems, if your still 6 volts that battery needs to be positive ground .
Scalawag
11-28-2002 19:24:57
Garth if you are up for anything, try removing the plugs and use your oil can and shoot about four shots of oil in each cylinder. This tends to seal the rings. Sometimes you can flood an engine and litteraly wash the cylinder walls of the oil they need for compression. I have used this technique several times when all else failed. It is worth a shot. Dave in Ohio.
Clay's-8Ns
11-28-2002 19:23:06
I have a friend who pulled the distributor off his 8N to set the points and somehow managed to get it back on 180*degrees out of time. His backfired also.Checked it for him and turned it around the right way and Wah-Lah it cranked right up.I wouldn't have believed it if I hadn't seen it.Hope this helps.
Clay
ZANE
11-28-2002 16:01:03
Sometimes when the ignition voltage is just marginal you can have fire at the spark plugs when they are out of the cylinder but when under compression they will not fire. This is because compressed air and fuel act as an insulator so that it is much harder for the spark to jump the spark plug gap under compression.
This could be from the plugs being fouled from gas or oil residue on them or the points could not be making good contact or the coil could be weak or the ignition switch may not be making good contact or the ignition resistor may be bad and not passing enough voltage to the coil.
Another thing that the N ignition does not like at all is carbon fibre ignition wires to the plugs or coil. You must have metal ignition wires to the plugs and coil. The carbon fiber wires may work OK when new but when deteriorated or old they just won't cut it.
Jim Spencer S.E. Michigan
11-28-2002 12:27:13
Garth;
You need fuel to the cylinders.
You need adequate spark to the plugs.
You need compression.
You need the plugs to fire at the proper instant, (otherwise known as proper timing).
If your spark is too weak it may fire the plugs when not under compression but will not fire when installed,(under compression).
Not much to this engine but it can be confusing to someone who does not have engine experience.
One of the things to be thankful for today is this forum.
Jim
shot in the dark==bj/8n/mt
11-28-2002 11:21:07
If I recall you post from the other day you had good fire at the plugs and good fuel flow at the carb. If that is right, pull the plug in the base of the carb and see how much fuel runs out. If it is less than a float bowl full I still suspect your float is hung up somehow from the recent rebuild.
Of course if that is the problem it ought to at least hit on the starting fluid but that is still my first thought.
Your mileage may vary
garth(IA)
11-28-2002 14:44:42
 Re: Re: 8N still won't start in reply to shot in the dark==bj/8n/mt, 11-28-2002 11:21:07
I took apart the carb, float didn't seem to be hanging up anywhere. I have it set a little bit more than 1/4" above the gasket.
