2N Gen Polarization
Zeke
05-30-2000 11:10:43
Folks, I have read the wealth of info on the 'board about "polarizing" the generator. When running I get less than 1 volt out of a newly rebuilt genreator (measured from the single post on the rear of the gen to ground) is this the best way to measure the output? (2) If I need to Polarize the gen; Do I run a wire from the neg term of the battery to the single pole on the rear of the gen, or is there some other set of connections that is better?
th
Claus
05-30-2000 13:59:15
 Re: 2N Gen Polarization in reply to Zeke, 05-30-2000 11:10:43
Yes, good way to measure..
2. Will do the job. If it is easier for you, you may take a jumper wire and short both terminals of the cutout relay for about 2 seconds. You should see a spark when you remove the short. Whatever method you find easier..
Happy Motoring
Claus
