Order Ford 8N Parts Online
8N TRANSMISSION NOISE IN LOW RANGE
JD
10-04-1998 19:51:18
My 8n has an England Reduction Gear box.In high the transmission sounds and works fine,but when its in low range its noisey and tries to jump out of low.Does anyone know if parts I might need are still available and what kind of job it would be to repair the transmission Any help would be great.THANKS JD
Nolan
05-30-2000 03:57:46
 Re: pto and hydraulics in reply to Jeff, 05-29-2000 18:22:39
Not without installing an engine driven hydraulic pump, and plumbing it into the lift circuit. It can be done, but is it worthwhile doing it...only you can decide that.
JD
10-06-1998 20:12:09
 Re: Re: 8N TRANSMISSION NOISE IN LOW RANGE in reply to jim duncan, 10-05-1998 15:29:44
To Jim,As near as I can tell we have a Howerd gear box.I was told that the gear boxes were either a Howerd or a Shermen and that the differance was with a Howerd the tractor only slowed down and with a Sherman the tractor and the PTO slowed down. If this is correct then mine is a Howerd and England is just a place of manufacture. If you have heard anything about this or any other info please let me know Thanks JD
E.Allison
10-05-1998 09:09:49
 Re: 8N TRANSMISSION NOISE IN LOW RANGE in reply to JD, 10-04-1998 19:51:18
I'm not familar with this reduction unit but I would look closely at the shift rail for wear. Regards, EEA
