Order Ford 8N Parts Online
8N resurrection
Jody
11-19-2002 11:13:01
*reposted from Restoration Board*
My father in law gave me an 8N tractor last week. It has been sitting outdoors for several years. With the exception of an electrical problem it was running fine when parked. I believe the problem was a 6 volt coil on a 12 volt conversion system.
I bought new plugs/wires/coil etc for it this morning and will get to work on it later this week. I know that I'll need to change the oil, clean the carb etc, but do I need to do anything else before I actually try to crank it?
If you have to know the year model I can't help you. I haven't removed the paint from the serial number yet. I have posted a link to a photo.
Thanks!
Read this before cranking the engine.........Jim.UT
11-19-2002 15:33:47
 Re: 8N resurrection in reply to Jody, 11-19-2002 11:13:01
From the archives.
Mike Schotte
11-19-2002 15:22:34
Congrats on the tractor. Looks like a pretty good starting point from what I can see...
Since your photo caption talked about the lichen growing on the tractor, I thought I'd show you the serious lichen on my new project tractor!
Happy Tractoring, -Schotte
Jody
11-19-2002 15:42:38
 Re: Re: 8N resurrection in reply to Mike Schotte, 11-19-2002 15:22:34
Thanks for the photo. You almost have a garden going there! Thanks to the rest of you for the help too, especially to the link with "good advice". If anyone thinks of anything else please feel free to share.
Tomtom
11-19-2002 14:21:54
I noticed that the shift lever boot was not covered up - best drain and flush out the trans and hyraulics. Lots of previous posts on doing this.
DavidO
11-19-2002 11:25:38
We don't have to know the exact year, but knowing whether it is front mount or side mount coil would be helpful. Let's discuss that "coil" issue before you get too far along. There is no reason why you need to buy a new coil, unless the old one is bad. The 6V coil can be used on a 12V system if it is hooked up correctly and with the correct components. We also need to take a look at the wiring in general and see what's hooked where. You probably would not believe the way some people hook these things up. There are many ways to do it. There are several correct ways and many wrong ways to hook up the wires. So, before you get too far along, let's talk about it.
Soundguy
11-19-2002 12:16:44
 Re: Re: 8N resurrection in reply to DavidO, 11-19-2002 11:25:38
After looking at the pic, we see an alternator on the right side. That pretty much concludes a front mount.
Guess this also means negative ground.
Now on to the resistor and other business.
Speaking ok 12v conversions. Anyone here have there stock genny rebuilt for 12v? Is it still positive ground?
thanks
Soundguy
DavidO
11-19-2002 12:30:48
 Re: Re: Re: 8N resurrection in reply to Soundguy, 11-19-2002 12:16:44
I still can't get the picture to come up. May be my browser. So, it has an alternator? I agree most likely 12V neg ground. If it is a front mount, is it a 6V or 12V front mount coil and is it good or bad?
BTW, the generator doesn't care whether it is positive or negative ground. Just polarize it accordingly.
Dave OH
11-19-2002 12:24:54
I also noticed that so we know it is pre-50 1/2 year model. I thought we went over what was needed to make sure the engine was free before trying to start before?
Dave OH
