Order Ford 8N Parts Online
8N dual range transmission
Jim Duncan
10-02-1998 13:53:55
I have what I believe to be a '51 8N (based on serial number on block. My tractor has a dual range transmission..the lever to engage the different ranges (high or low) is located on the right hand side of the transmission. The cover plate through which the lever goes indicates that it was made somewhere in England, but I can't make out the manufacturer name or model number - if there is one.
Does anyone know anything about these "aftermarket" addons? Are they still available. The reason I need the dual range is to allow a rear mounted snowplow to be attached to a second 8N that a buddy of mine has.
Thanks
Joe
10-03-1998 16:28:28
 Re: 8N dual range transmission in reply to Jim Duncan, 10-02-1998 13:53:55
Sounds to me like you have one of the highly sought after "Howard Rotovator" rearend gears.
These are really great, particularly useful for slowing down "Ford's better idea high speed reverse"!!!
Joe in NH
CW
10-02-1998 20:41:07
I had an 8N with hi-low actually found out that it was a 3 range. You have to turn the steering clear to one side to be free from the drag arm--then you could use the lever to move the shift arm out and up to get a super-low range. I had the tractor torn down once--this transmission just sets between the clutch and the main transmission--but I couldn't see any name--I do have a small manual on a Hupp Dual-drive unit but not sure if it was from this tractor or not. Hope it helps.
Vic in OK
05-29-2000 09:53:46
 Re: Re: 8n hydraulic pump in reply to dave#1, 05-26-2000 04:57:24
Dave
Saw your response to Larry's question. Wondering if you wouldn't mind another question. Have noticed the 3pt still will lift (on my 8N)implements, but very slowy. Any ideas?
Thanks.
