Bearing Sizes
Mark Steffy
05-28-2000 09:09:20
I am rebuilding a 1939 9N. I need to rebuild the engine, but I don't know how to determine the rod and main bearing sizes for the rebuild kit. Can someone please help with this information. Thanks
Claus
05-28-2000 09:48:23
 Re: Bearing Sizes in reply to Mark Steffy, 05-28-2000 09:09:20
The proper sequence is to strip the engine down and send the crankshaft out to a reputable machine shop. The machinist will tell you the size of the bearing shells needed. There is no way of knowing before machining how much material has to be removed from the bearing journals until the machining is begun. First one would remove .010 and if that cleans it up then you would need .010 oversize bearing inserts. If that will not do it then you would keep on going to the next oversize which is .020.. Sometimes if the journals are so badly scored, then the crank would be trash.. Usually .040 is the largest size but I heard of one outfit that made .050 ovesize bearings. The same would apply to an engine cylinders if you did not have replaceable sleeves as found in Automobile engines. I usually took my blocks to a machine shop that also had the bearings in stock and would get the crank returned with the correct inserts and the oversize pistons with rings. Of course this is not a problem with sleeved engines. You can order rebuild kits without the bearing inserts if you want to order the parts in advance.
Happy Rebuilding
Claus
