Order Ford 8N Parts Online
Installing bushings/bearings in 48 8N
Just an Old 8N
09-30-1998 18:52:22
Just took apart the front spindle on a 48 8N, took bushings and bearings out, going to New Holland Dealer to get new parts. Now, when you replace the bushings and bearings, do you put the bushings in first, then the bottom bearing, and then the spindle? I read that freezing the bushings and heating up the housing helps with installation, but do I need the special tool that the N-Board has mentioned for removing the bushings, to install the new ones?
Donna
E.Allison
10-01-1998 11:59:24
 Re: Installing bushings/bearings in 48 8N in reply to Just an Old 8N, 09-30-1998 18:52:22
Do you mean the bronze bushing in the front axle? If so, no special tools are needed. Just find a socket of the right size and be gentle. (If you need a large ape to drive them in, stop, something is out of alignment). Freezing and heating is not necessary. EEA
