Order Ford 8N Parts Online
8N Birth Date ?
Danny Bracken
09-26-1998 18:20:07
I have an 8N that I just discovered has a 9N s/n on the engine block-9N131236, apparently the result of a previous engine change. Does anyone know if there is a way to determine the build year? I believe it to be pre-'51 as it does not have a proofmeter. Thanks for your help!!
Ariel
05-26-2000 11:21:50
 Re: Re: Re: oil check in reply to Chuck, 05-25-2000 21:15:49
Gosh, does that mean I am supposed to wear pantyhose when I mow? That would pretty uncomfortable.
John Smith
09-26-1998 22:55:54
 Re: 8N Birth Date ? in reply to Danny Bracken, 09-26-1998 18:20:07
Crawl under the tractor and wipe off the area just in front of the drain plug on the hydraulic pump base. The actual casting date of the pump will be there in mm-dd-yy format. - IF- your pump hasn't been changed, your tractor was most likely assembled within a couple of weeks after this date.
Claus
05-26-2000 11:07:34
 Re: Ammeter reading in reply to JAE-Tx, 05-26-2000 10:13:09
If your battery is healthy, then it will show a slight discharge when starting (ignition current) and then after it starts show about a 5 amp charge to replenish the current used for the starter. This may only be a couple of minutes and then the ammeter would show zero... or a slight charge..
Hopefully, you reversed the leads to the ammeter when you changed from pos ground to neg or if you still have the electrostatic ammeter, put the lead through the other way...
Happy Motoring
Claus
Don B
09-26-1998 18:41:46
Need more info.Such as front or side mount Distributor.Casting dates on rear axle.What type of steering box,adjustable or "non-adjustable"?Any other numbers or letters and their location on tractor.I believe some of the guys can get you close.Let us know,Don
ZANE
05-26-2000 08:51:51
 Re: Re: Tractor show at Point Mallard Alabama near Decatur in reply to Jeff, 05-25-2000 21:43:03
I am putting that on my calandar and see if I can make it there. I'll be the one with the silly looking backpack.
Something I learned from the grand kids.
Dan
09-26-1998 22:00:48
 Re: Re: 8N Birth Date ? in reply to joe m, 09-26-1998 18:41:32
1947? Think so?
The serial number on the engine, 9N131236, seems to indicate a production year of 1944. Engine is out of a 2N.
Dan
NAA60512
