Order Ford 8N Parts Online
8n hydraulic pump
Larry
05-25-2000 17:33:58
I have an 8n that will only lift the 3 point arms when there is no weight on them. When an implement is hooked up they will not raise. I have removed the pump and would like some tips on what to check and look for on rebuilding the pump. Also where is a good place to get a rebuild kit? Thanks.
dave#1
05-26-2000 04:57:24
 Re: 8n hydraulic pump in reply to Larry, 05-25-2000 17:33:58
third party image
Look for hair line cracks in the pump houseing and valve chambers (Heads), I've had to replace both valve chambers on my 50 8n because of cracks from freezeing. I bought 1 used and 1 new valve chamber from Walt's tractor parts, I also bought a the small parts package for the valve chambers from Walt's, It gives you everything, all the valves,pins,springs, ect.
Hope this helps
later,dave
Vic in OK
05-29-2000 09:53:46
 Re: Re: 8n hydraulic pump in reply to dave#1, 05-26-2000 04:57:24
Dave
Saw your response to Larry's question. Wondering if you wouldn't mind another question. Have noticed the 3pt still will lift (on my 8N)implements, but very slowy. Any ideas?
Thanks.
